QUOTE(Olympic 914 @ Feb 9 2021, 07:55 AM)
Another Winter project in the works is changing out the wheel studs to bullet nose studs and adding some spacers to the front to push the wheels out a couple mm.
Question How hard is it to remove the rear studs? I have a 5 bolt conversion to rear hubs. Would rather not pull the hubs apart and possibly damage the bearing.
I know I'll have to remove the rear caliper and the rotor dust cover. Can I just take a hammer and tap each out ? is there space to do this?
could probably pull the new ones in with a spacer and a nut on the studs.
It would be nice if there was some kind of puller I could use to press them out.
The fronts shouldn't be a problem, as I have a 911 front end and the studs are in the aluminum hub.
@Olympic 914
on the rear studs:
If the studs are 45 or 50mm in length you can remove them with the hub installed. I use a steel open end lug bolt installed with the top flush with the end of the stud. I place one hammer against the nut and strike it with another 3 lb hammer. 2-3 hits and they are loose.
When installing the new studs get one 5/8" washer and two 14mm hardened washers. You need the (1) 5/8" washer on first to clear the splines of the stud with are larger in diameter than the threads, (2) hardened 14mm washers, and a 14 x 1.5 flange nut.
Grease both sides of the washers and the bottom of the flange nut. Na alternative to the14mm washers is a pair of the keyed washers used on the front struts spindles. Either the 914 or 911 will work. the 911 have a larger hole. I use a 4 way lug wrench to spin the nut. It takes considerable force to pull them in. This method reduces the force required and the possibility of pulling the threads on the stud.
To prevent the axle from turning as you pull in the studs I use a piece of chain. Elongate the end link so it will slide over a stud. Wrap the chain around the trailing arm and use a through bolt to connect the other end of the chain to itself. Rotates it to take out all of the slack. An old bicycle inner tube slid over the chain will protect the trailing arm from sratches.
You need to remove the hub from the rotor on the front hubs to change them as there is not enough clearance. Knock the studs loose before removing the hub. Use an impact to loosen the 8mm nuts that hold the rotor to the hub. It usually works with no back up wrench. Draw them in with the same method described above.
I can lend you the installation parts for the cost of shipping.
Bruce
