QUOTE(Mark Henry @ Feb 11 2021, 02:36 PM)
A crush washer won't work, it expands and contracts too much. It has to be a rubber O-ring of some type.
If I recall, they initially came with rubber O-rings that went under the washers into a slight chamfer. Mine eventually tore and I was left empty handed.
Back in the day when I was broke, I used to cut a 1/8" to 1/4" piece of rubber hose with a reasonable ID to fit the M8 bolt and put it under the washer and it sort of got forced down into the chamfer of the valve cover bolt.
Not going to lie, sometimes I would get very minor weepage past that homebrew seal.
When I use these type valve covers again in the future, I'll probably custom machine a bobbin or washer arrancement with an O-ring but it will probably also involve some machine work to the cover itself to make it work.
