I have these 1.7 components. It's not complete, but a start. If you're interested PM me an offer. I can't guarantee any of the parts and I would definitely have the injectors "rebuilt". I believe the large rubber piece connecting the air filter to air box will need replacement (available at 914Rubber). Of course the AAR is always suspect too. The ECU part number is not legible, but it does have the idle adjustment. The plastic around the idle adjustment knob has crumbled a bit.
The big items missing are:
- MPS
- Distributer with trigger points
- Decel valve
- anti-flashback valve (if your heads are still vented)
- PCV
- Second larger bracket for ECU
- Various connectors
- I'm sure others can tell you what else is not in the pictures.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
