QUOTE(ClayPerrine @ Feb 18 2021, 02:20 PM)
You can decertify an aircraft to put the PFM in it.
Unfortunately, not an N-reg'd airplane in the USA. I (and others) have tried to do it* and it was rejected. The best the FAA would offer is a temporary Experimental cert, Research and Development, but it had to be temporary and the aircraft ultimately returned to its original airworthiness cert.
We even went so far as to try and convince the FSDO with something like, "well, what if I <wink wink> built the Tiger airframe from scratch, and used gear and wings, and controls, and all a lot of parts from a Tiger, such that it looked a whole lot like a Tiger? Could I get Experiemental cert for that?" and the guy was like "<hard stare> you prove you built those wings, and fuse, and empanage, and so forth from scratch, greater than 51%, I'll give you an E-cert. But you better have a lots of photos and video." And of course, no DER would touch that third rail...
In Canada you can de-reg your certified airplane for owner maintainance. But not in the USA.
*We wanted to install an M20J IO-360 with a C/S prop on my Tiger. But the amount of work, and hassles, and money involved to get an STC was absolutely incredible. We watched a guy do the whole shebang to get the IO-540 installed in his Tiger and said, "eff that". Killer install but absolutely no way was I going to create that kinda pain...
Here's the masochist, if you want to listen to his story:
https://www.youtube.com/watch?v=mtrCFCOZ8g8...channel=GregAmy
