QUOTE(Spoke @ Feb 17 2021, 06:52 AM)
Check out this thread about LED headlights and interaction with foglights. The OEM 914 has the foglight relay powered in series with the high beam filament. This works for incandescent bulbs but fails with LED headlights.
The simple solution is to parallel a high power ballast resistor across the high beam or modify the wiring to the foglight relay as detailed in the thread. I don't like adding ballast resistors as they burn a lot of power (that you saved going to LED lights) and they can get very hot.
914 LED Headlights + FoglightsQUOTE(GregAmy @ Feb 17 2021, 08:39 AM)
Or, rewire your foglight circuit so that it is independent of the low beams:
https://members.rennlist.com/demick/fogrewire.htmleither of these should work, i did what SPOKE suggested, as i have his LED fog light conversions and i have LED hi/low headlight too and now both work fine and i can have my fog lights on iwht or without the headlamps on.
