I pulled all of the old hard loom off of the harness that goes from the Regulator plate to the engine. The reason is inspecting one end I could see that one wire had gotten so hot that it melted the insulation. This was the Black/purple wire. Now that I have it completely open I need help identifying the wires. The previous owner did a half ash job splicing and I can't tell where they go. In the picture the wires I'm sure of are the two Grey/brown wires (back up lights) The green wire (Heater blower), Yellow wire (starter solenoid) Black/red larger wire ( I'm thinking this must power the ignition), Small Black /purple wire ( thinking it goes to the negative side of the coil and is the Tach. It's also the one that melted) Which leaves a small white wire and a green/red wire. (these are probably sending unit wires for the oil pressure and head temp sensor but which is which I don't know. Anyone? Bueller...Bueller?
