SOLD
This is a set of parts you will need to convert to a side shift trans. It does not include the internal transmission parts. You will either need a complete side shift trans or the shift console and shift forks.
The set includes:
Powder coated engine bar, front and rear shift rods and engine to bar brackets.
New rubber engine mounts and hardware
New engine bar to body brackets and hardware
Both shift couplers for the rear shift rod
Shifter in good shape with little wear on the detent plate
New cone screws and all bushings
New rear bellows and shift console cover (missing from picture)
Used front bellows for rear shift rod.
Eginge bar and rear shift rod have been straighten.
Price is $500 plus shipping which should be about $50.
Only part not included is the drivers side warm air guide. I am working to convert the early guide to the late by reversing the direction of the hump.
