neo914-6
Jul 18 2005, 10:56 PM
Seller had it listed on CL but went ahead and sold it to pick-n-pull.
Maybe a complete car, maybe good for parts, just passing the info.
Good hunting...
bondo
Jul 18 2005, 11:24 PM
Pick n pull in oakland, or at the oakland street exit in san jose?
neo914-6
Jul 19 2005, 12:02 AM
QUOTE (bondo @ Jul 18 2005, 09:24 PM) |
Pick n pull in oakland, or at the oakland street exit in san jose? |
Oakland, CA
The Pick-a Part in SJ is not on Oakland St, it's off on Commercial I think...
Jul 19 2005, 12:18 AM
QUOTE (Neo914-6 @ Jul 18 2005, 11:02 PM) |
Oakland, CA |
we have a "Pick n Pull" ???
where ????
Andy
Dead Air
Jul 19 2005, 12:37 AM
Grab that motor!!!
neo914-6
Jul 19 2005, 12:44 AM
He said Oakland but must have meant:
Pick-N-Pull
(510) 233-7341 1015 Market Ave
Richmond, CA
He is from Alameda...
tat2dphreak
Jul 19 2005, 07:59 AM
if you gget the motor, get the tranny too... he had to flip one or the other to make it work... and the tranny was probably easier...
Jul 19 2005, 09:58 AM
QUOTE (Neo914-6 @ Jul 18 2005, 11:44 PM) |
Pick-N-Pull (510) 233-7341 1015 Market Ave Richmond, CA |
interesting ...
bd1308
Jul 19 2005, 10:12 AM
QUOTE (tat2dphreak @ Jul 19 2005, 07:59 AM) |
if you gget the motor, get the tranny too... he had to flip one or the other to make it work... and the tranny was probably easier... |
reverse cam.
tat2dphreak
Jul 19 2005, 10:32 AM
QUOTE (bd1308 @ Jul 19 2005, 11:12 AM) |
QUOTE (tat2dphreak @ Jul 19 2005, 07:59 AM) | if you gget the motor, get the tranny too... he had to flip one or the other to make it work... and the tranny was probably easier... |
reverse cam. |
or reversed ring on the tranny...
or just a 911 tranny
bd1308
Jul 19 2005, 10:36 AM
flipped diff introduces other possible weaknesses. reverse cam is the way to go. Dr evil used to have a corvair motor.....
dunno about the 911 tranny though. makes sense.
Andyrew
Jul 19 2005, 11:35 AM
Grab the whole freekin thing...
I bet pick and pull would be glad to get rid of it....
bondo
Jul 19 2005, 11:40 AM
QUOTE (Andyrew @ Jul 19 2005, 10:35 AM) |
I bet pick and pull would be glad to get rid of it.... |
Tried to do that once. No dice. Once they're tagged for salvage, they legally can't sell the whole car.
Andyrew
Jul 19 2005, 11:52 AM
pick and pull in modesto has cars that are for sale...
interesting.
bondo
Jul 19 2005, 12:02 PM
When they get a car, they make the decision to sell whole or parts. Once they choose parts, they fill out paperwork with DMV, and it stops being a car and becomes parts. I once saw a car in the off limits area that hadn't been moved to the yard yet. They had already filed the paperwork, so I couldn't buy it.
Hawktel
Jul 19 2005, 12:45 PM
QUOTE (bondo @ Jul 19 2005, 10:02 AM) |
When they get a car, they make the decision to sell whole or parts. Once they choose parts, they fill out paperwork with DMV, and it stops being a car and becomes parts. I once saw a car in the off limits area that hadn't been moved to the yard yet. They had already filed the paperwork, so I couldn't buy it. |
Man if I was a Junkyard owner I'd just keep all of them as cars, so if some nut came and wanted some beat up wreck, he could buy it.
bondo
Jul 21 2005, 12:37 PM
Has anyone verified that this car is at the Richmond pick-n-pull and available for parts pulling?
Red-Beard
Jul 21 2005, 09:08 PM
QUOTE (bd1308 @ Jul 19 2005, 08:36 AM) |
dunno about the 911 tranny though. makes sense. |
Why? 911 Transmissions run that direction. Mike was rebuilding the motor anyway so he used the reverse cam. I tried to convince him to use the reversed differential.
neo914-6
Jul 24 2005, 11:31 AM
Sorry Royce, there is an Oakland PNP as you found out too late:
OAKLAND, CALIFORNIA
8451 San Leandro St.
Oakland, CA 94621
Here's link for future ref:
http://picknpull.com/
bondo
Jul 25 2005, 03:15 PM
Ok, I have indeed verified that there is NOT a 914 in the Richmond pick-n-pull. I did not get to the Oakland one in time. Do any people more local (it's a 4 hour drive for me) care to see if it's in the yard? I may make the trek again if it looks to be worth it.
Jul 25 2005, 04:03 PM
QUOTE (bondo @ Jul 25 2005, 02:15 PM) |
Ok, I have indeed verified that there is NOT a 914 in the Richmond pick-n-pull. I did not get to the Oakland one in time. Do any people more local (it's a 4 hour drive for me) care to see if it's in the yard? I may make the trek again if it looks to be worth it. |
i could run over there and have a look. but i don't have a camera right now, can you wait 'til thursday?
Andy
bondo
Jul 25 2005, 07:02 PM
I don't think they allow cameras, but if you can sneak one in..
I'm in no big hurry.
ClayPerrine
Jul 25 2005, 09:18 PM
QUOTE (Red-Beard @ Jul 21 2005, 09:08 PM) |
QUOTE (bd1308 @ Jul 19 2005, 08:36 AM) | flipped diff introduces other possible weaknesses. reverse cam is the way to go. Dr evil used to have a corvair motor.....
Why? 911 Transmissions run that direction. Mike was rebuilding the motor anyway so he used the reverse cam. I tried to convince him to use the reversed differential. |
911 transmissions run in the exact same direction as a 914 transmission. The only difference is the locaiton of the ring gear. That is why it drives in the opposite direction. Even in reverse the input shaft runs the same direction, and the pinion shaft is turned in reverse at low speed , and for a short time only.
If you reverse the rotation of the input shaft on a transmission, every internal part runs in the opposite direction. The shafts have thrust bearings that take the load caused by the helical cut gears. If you reverse the rotation of the shafts, you are running against surfaces that were not designed to take a thrust load.
The only proper way to make a Corvair motor to a 901 transmission is to install a reverse rotation cam in the Corvair motor.
Cap'n.. Can I get your input on this????
bd1308
Jul 25 2005, 10:09 PM
yea
i remembered right.
