QUOTE(bkrantz @ Mar 4 2021, 09:45 PM)
I am about to install new vinyl and padding (from RD). The original padding was glued completely to the metal dash top, and the original vinyl was glued only along the edges or where wrapped over the edge. It was not glued to the padding.
Some methods I have seen for replacement do glue the vinyl to the pad.
Opinions? Having the vinyl "loose" seems like it will let it stretch evenly, and maybe avoid wrinkles in the future.
out of curiosity i pulled my old lhd dashboard out which still has the vinyl attached.
as you say it is glued only to edges .
my guess is glued to the foam, air trapped in the foam, on hot days might bubble in areas where the vinyl might not have adhered to the foam or the adhesion breaks down.
i'd guess reason for factory not gluing to foam is not so much for wrinkles as bubbles forming under the vinyl? hot air expansion in the foam can disperse more evenly if not glue?
