Niklas
Mar 7 2021, 03:49 AM
Who sells tumblers ( Wafers ) and springs now?
Niklas
914Sixer
Mar 7 2021, 06:57 AM
914Rubber was going to make them but not sure IF i ever happened.
ConeDodger
Mar 7 2021, 07:07 AM
bdstone914
Mar 7 2021, 08:43 AM
QUOTE(Niklas @ Mar 7 2021, 03:49 AM)
Niklas
I have lots of used tumblers with wafers and springs. Some sells repros them new as a VW part.
pete000
Mar 7 2021, 09:27 AM
Do a search on the Samba for Gabriel Locks, he rebuilds VW locks.
iankarr
Mar 7 2021, 09:54 AM
Also Curt Curtis on FB
Mikey914
Mar 7 2021, 10:08 AM
Yes these are on the list. I have not seen new. The problem is that if they are used they can be worn unevenly.
You may have to go through a few to match your ignition key to the door.
Are new available now and how much are they?
bbrock
Mar 7 2021, 10:22 AM
I bought new wafers and springs from member
@tweet a few years ago but he hasn't been active here for a couple years. He was getting new wafers from someplace though so they must be available.
bdstone914
Mar 7 2021, 10:41 AM
bdstone914
Mar 7 2021, 10:44 AM
@Niklas
This looks like the source
https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspx
willieg
Mar 7 2021, 11:07 AM
I have had good response from keys4classics.com. They are an Aussie company.
bdstone914
Mar 7 2021, 11:57 AM
QUOTE(Mikey914 @ Mar 7 2021, 10:08 AM)
Not that much. Maybe buy the 400 kit and repack.
https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspx @Mikey914
TheCabinetmaker
Mar 7 2021, 02:41 PM
Those are not the same. They are made for cam style locks. They are not the same size. I've checked all those vendors and they state that they will not fit automotive locks.
Mikey914
Mar 7 2021, 05:31 PM
I'm totally down with buying in bulk and reselling in bit size pieces to make stuff reasonable. Just gotta do my homework to make sure its correct.
TheCabinetmaker
Mar 7 2021, 06:03 PM
QUOTE(Mikey914 @ Mar 7 2021, 05:31 PM)
I hope you can find them. I've had two porsche parts professionals looking for a source with no luck.
Mikey914
Mar 7 2021, 07:10 PM
Which is why we were looking to make them.
The tooling is not cheap.
JeffBowlsby
Mar 7 2021, 07:47 PM
QUOTE(willieg @ Mar 7 2021, 09:07 AM)
Their website says they only do keys, not locks
914Sixer
Mar 8 2021, 06:26 AM
Lets be clear, VW wafers and 914/911 wafers are COMPLETELY different thickness. Not interchangeable.
TheCabinetmaker
Mar 8 2021, 06:31 AM
Mark nailed it. Vw wafers will NOT fit!
Niklas
Mar 9 2021, 04:31 AM
QUOTE(bdstone914 @ Mar 7 2021, 06:57 PM)
https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspx @Mikey914It says that these does not fit car locks.
Niklas
Root_Werks
Mar 9 2021, 12:46 PM
QUOTE(bdstone914 @ Mar 7 2021, 08:44 AM)
@Niklas
https://www.easykeys.com/1831_ESP_Cam_Lock_...RK-30-0000.aspxI bought this kit, worked great. Now I have a hundred extra wafflers and springs.
914Sixer
Mar 10 2021, 07:21 AM
IF this is a correct set, it is the answer to everything.
TheCabinetmaker
Mar 10 2021, 07:36 AM
QUOTE(Root_Werks @ Mar 9 2021, 12:46 PM)
@Niklas
I would be happy to take your leftovers.
Mar 10 2021, 07:46 AM
QUOTE(Root_Werks @ Mar 9 2021, 01:46 PM)
@Niklas
Thank you for posting. I have looked in the past but never was able to find a kit. Tweet used to charge the same amount for about 20 wafers and springs.
Edit - I just ordered. Super easy and fast.
Root_Werks
Mar 10 2021, 09:58 AM
I'll have to check the kit I bought. Worked on doors and rear lock perfect. Even wrote down which wafer went where so I have a good key code.
frostyf
Mar 10 2021, 10:03 PM
QUOTE(Root_Werks @ Mar 10 2021, 10:58 AM)
Hey Rootwerks, is this the solution? Despite the comments about not fitting car locks, did these wafers work in yr locks??
I tried some 924 wafers but they must be like the VW ones as they were too thick and too large! Keen to find a source that works!
Mar 15 2021, 12:59 PM
I just got mine today. I’ll try them in some lock cores shortly. But I got to believe that if Root says they work, they work.
eric9144
Mar 15 2021, 01:33 PM
Very curious to see the outcome on this, have literally just gotten all the odds and ends pieces to pull apart both of my doors and pull F/R trunk and Passenger tumblers out to match them to the ignition and drivers door key. Didn't want the car pulled apart for too long while the locks were being re-keyed and didn't want to have to do it 2x
TheCabinetmaker
Mar 15 2021, 03:17 PM
I too ordered the set from easy key. They are not the same. They do fit the cylinder, but the length overall, and the height of the key slot are smaller. I've already tried to key a cylinder with them. The key slot being smaller makes it difficult or even impossible to insert the key, depending on the cut of the key. They do slide into the cylinders, but that's about it. All in all, not a viable solution for me.
Root_Werks
Mar 15 2021, 03:22 PM
That looks like the same kit I bought. I'll check when I get home tonight. I did doors and rear lock. They fit perfect. BUT, gotta double check the kit.
Dunno about ignition.
gord
Mar 16 2021, 06:35 PM
Subscribing to this thread because I need to rekey 3 of my locks in the near future. I did find the ASP kit (A-26-101), but it seems impossible to purchase unless you are a licensed locksmith.
@mepstein - please let us know how this kit works out for you!
Gord
Root_Werks
Mar 17 2021, 08:36 AM
QUOTE(mepstein @ Mar 15 2021, 11:59 AM)
Yup, that's the ESP kit I have. The wafers worked and I didn't need any springs so don't know if those worked.
Again, this was just on doors and rear lock. Haven't tried them on glove box or front trunk handle yet.
TheCabinetmaker
Mar 17 2021, 09:35 AM
Here's a comparison between the two. You can clearly see the difference. The key slot is different. The length is different. There is a small tit on one side of the esp wafers. They might work with a particular key, but they will not work with all keys. I've tried to mock up with 3 different keys in 3 different cylinders. All were failures. I fear there will be trouble with them down the road. I will not be using these on locks for my customers. I just can't guarantee them.
TheCabinetmaker
Mar 17 2021, 09:41 AM
The esp wafers are also not as wide, and quite sloppy side to side. This could easily hang up in the cylinder.
The springs work just fine.
Root_Werks
Mar 17 2021, 10:20 AM
Will admit I didn't notice the thickness difference between the wafers.
So it seems the ESP kit isn't truly a perfect replacement for proper wafers. I'm happy with how my locks operate though. The key is pretty smooth and at least the ESP kit allowed me to get all my locks to match.
Years ago I had tons of 914/911 keys and lock parts including wafers. Shoulda kept them!
TheCabinetmaker
Mar 17 2021, 10:26 AM
That's why l have saved every lock l can. Still, l run low on #4 wafers. For me, the springs alone are almost worth the cost.
Dobbsy
Mar 17 2021, 10:58 AM
I am still waiting for mine to arrive, I will deffinately need the springs, shame about the wafers.
On the topic of keys, which key would a 914-6 have been sold with, the only key I was given is the Porsche Audi one. Should I have the black and red ones.
Click to view attachment If its the black and red ones, for the valet key which wafer indentation should be missing or was it random.
If its the Porsche Audi key what did they do for the valet key
TheCabinetmaker
Mar 17 2021, 11:32 AM
All 914s and early 911s came with a master and valet key, as far as l know. The valet wafer replaces the #3 wafer. Some wafers aren't marked. The#3 will measure approximately 0.169 from bottom of slot to bottom of wafer.
PCH
Mar 17 2021, 01:52 PM
I agree with Root Werks. I used the ESP kit wafers to help me key all my locks to the ignition lock. Worked out fine. Amazing how many locks a 914 has!
