QUOTE(Tom_T @ Mar 12 2021, 01:13 PM)
QUOTE(DC_neun_vierzehn @ Mar 11 2021, 09:05 PM)
Hello. First post here so please be gentle ; )
Please note: I did a few searches prior to posting, but could not find answers to my question.
I will be buying my first 914 later this month ('73). She has black bumpers (not chrome) with bumperettes on the front. I love keeping it as original as possible, but I don't think I can deal with this one part of her appearance. Just can't.
I've researched how to remove them and quickly found that answer (remove the bumper to access the bumperette bolts). But ... I'm hoping others who have done this can share pics of what it looks like after the bumperettes come off. And what did you do with the holes? Has anyone discovered plugs or other solutions to fill the holes cleanly?
Thanks in advance for your help.
DC -
You may have one of the few still original late `73 MY 914-2.0 Sport versions - which were decontented some previously included options in order to keep the prices down as the W. German Mark escalated against the US dollar.
You don't say how original it is, but if it is mostly original - then you probably should do nothing that isn't easily reversible. Otherwise, you may negatively affect it's long term value as a collectible 914 example.
So if really cannot stand those front "Tits" Bumper Gaurds - then do the least invasive option suggested above - remove them; clean them up, box & save ALL of the parts including the rectangular rubber pads on the back braces - which are NLA now except as repros; and put some black plastic or metal caps over the holes - don't weld the holes since those bumpers with the 4 back braces & the extra sets of mounting holes are also NLA (even the SS repro bumpers don't have the holes & extra set of back braces). But check the capped holes for rust issues & treat them as necessary every year.
You should also get the VIN & Chassis # (at rear trunk floor stamping & on Karmann Plate at L front door jamb, with paint code) - which will allow you to determine the production date from the Chassis #.
VIN Decoder:
https://bowlsby.net/914/Classic/zPLM_A3-Decoder.jpg Chassis # Decoder:
https://bowlsby.net/914/Classic/zPLM_A4-Decoder.jpg(Note that the 5 in 95 could also be used for hundredths car built that day if a 1 or 2 or 3 - 100, 200, 300 & XX for the other 2 digits) Also do your research & get the 914 assessment form at Jeff Bowlsby's website:
https://bowlsby.net/914/Classic/ http://bowlsby.net/914/Classic/zTN_Gen_914CAF.pdf And also p914.com (& .org & .net) is another good info resource for you.
You should also contact Dave K on here to chat about his 914-2.0 Sport & yours:
http://www.914world.com/bbs2/index.php?showuser=12234 Good Luck!
Cheers!
Tom
That's exactly what this '73 is (a rare 2.0 Sport).
Absolutely, I would not do anything permanent. If I take the bumperettes off, I would keep them and all of the associated pieces stored away in case I ever want to have the original appearance again.
Sounds like simple black plastic/rubber plugs are the way to go to fill the holes. Folks bring up a good point though ... who knows what the bumper looks like with those off (what wear/tear/fading/corrosion is underneath the bumperettes).
Depending upon the answer to that question ... the bumperettes might go right back on.
Thanks for all the info everyone.
If anybody has pics of their front black bumpers with the bumperettes off and simple, removable black plugs popped in there ... please share?
