Hey guys, went for a cruise the other night,
I believe I shifted into reverse instead of 2nd coming up to a stop, going about 5mph.
Little grind, caught it quick and proceeded.
Later, going to back out of the driveway, I no longer have reverse.
Goes into all 5 forward gears fine. I can put it in the reverse gate area, let the clutch out, nothing happens. Just a “whirring” sound from the transmission.
I have a spare transmission, which I wanted to swap to anyways. (Much cleaner)
I already have the transmission removed (needed to pull the motor for a few small things)
Anything I should look for? I popped the Rear Cover (#5 in Haynes) off, not seeing any obvious wear on the 1st/Reverse twin gear. (#9 in Haynes)
I don’t think it’s a RLO issue it clicked right into the reverse on the lever.
Any ideas are appreciated.
Cheers!
Edit: Tail shift. 1971.
