QUOTE(Mark Henry @ Mar 16 2021, 03:23 PM)
Note on aircooled nickies I run a .005 gap on a 102mm piston because I can, the pistons and cylinders have a similar expansion rate.
Here's why that can work out on a set of Nickies.
Piston and Cylinder are Aluminum. Aluminum coefficient of thermal expansion is almost two times higher than that of steel (i.e. the rings).
As you state the piston and the cylinder are expanding at identical rates. This keeps pistons from scuffing and/or collapsing the skirts with your relatively tight Mahle pistons. If you had those kind of tight piston fits in a steel cylinder you would have problems. Not so with Nickies and/or Porsche OEM 2.7L cylinders and larger that are aluminum.
Since the aluminum piston bore is expanding faster than the steel ring and you'll get a slight
increase in ring gap as things are at operating temprature. I have a set of Nickies and JE pistons on reserve for a future project. They are still recommending a .004" gap / inch of piston bore though. Have you ever done leakdown on that engine? It must be awesome! Gotta' be close to using Total Seal Ring!
In typical situation for T4 engine with cast iron cylinder and steel ring. Agree completely with your previous comment that ring gap stays roughtly the same since the steel ring and the cast iron cylinder have nearly identical expansion rates.
Interesting fact. Formula 1 engines run almost zero ring gap at ambient temperature.
Same principle as Nickies, aluminum block, steel ring.
In order to make this work, you'll notice the engines are pre-heated prior with an external heating pack that pumps hot coolant though the block. This warms the block and provides operating clearance for the ring at operating temperature. This pre-heat sequence is done prior to firing up the engine. Otherwise the thermal expansion resulting from combustion will heat the top ring much faster (initially at start up) than the aluminum block. You woud get ring breakage since the ring was starting with zero ring gap at ambient and would initially expand the ring faster than the block (which has a lot of thermal mass as compared to a piston ring).
Another intersting fact is that the rings are the main heat transfer mechanism from piston dome to cylinder walls. In a 911 engine oil squirters are another mechanism to cool the piston dome but most engines don't have piston oil squirters and the rings are the main heat transfer mechanism.
Rings seem really simple but they serve multiple functions. Sealing, heat transfer, and oil control. A lot to ask from a little piece of spring steel.
