Tdskip
Mar 14 2021, 06:27 PM
If I am using Ben’s tank or all of the ancillary seals and fittings from PET the right ones to order? I assume so but wanted to check real quick.
So #46 and 48 etc all PET part numbers from regular vendors (and Ben as much as possible)?
Mar 14 2021, 07:41 PM
46 is the rubber gasket that surrounds the oil filter console. 48 is an overpriced foam ring.
Tdskip
Mar 15 2021, 07:04 AM
Thanks Mark, sounds like I should look at the alternatives discussed here.
Tdskip
Mar 15 2021, 07:05 AM
Mar 15 2021, 07:54 AM
QUOTE(Tdskip @ Mar 15 2021, 09:04 AM)
46 is needed. The metal ring -45- fits into it. Both 45 and 46 are 911 parts as well so they are easy to find. I purchased both the foam rings (2 different sizes) at Sunset Porsche. they are $40 each. Ben told me he uses foam hardware tape. Probably works just as well as the overpriced foam rings.
gms
Mar 15 2021, 08:10 AM
Uro parts makes a nice #46 rubber seal
roblav1
Mar 15 2021, 06:50 PM
I made my own #48 from foam and hole saws.
Tdskip
Mar 15 2021, 08:01 PM
Thanks gentlemen, appreciate the information and tips.
Tdskip
Mar 16 2021, 03:06 PM
Just to try to contribute something back here it turns out that Pelican has all the stuff in stock, and the prices seem workable, if not quite cheap.
930cabman
Mar 16 2021, 06:20 PM
QUOTE(Tdskip @ Mar 16 2021, 04:06 PM)
Not far behind you TDskip, thanks for posting
