Here's some feedback on Ben's 1.8 muffler. Also wanted some input regarding fitment.
Finally received the muffler last week. Unfortunately, UPS placed a small dent noted upon unboxing despite the amount of packing inside the box. Not noticeable and small once installed. Just annoying. Not sure worth the hassle dealing with UPS. Came with the bolts and gaskets.
Sound is louder than I expected especially on startup/cold. Once warmed up, at idle its quiet. But at acceleration and high rpms (4-5k), it howls. Very sporty sound. This is not the quiet version after all. Theres a musical tone to the muffler that reminds me of the Scart muffler. Sounds heavenly even cruising at 3-4k rpm.
Overall finish looks solid. Flanges are flat, true, and quite thick. Fit was bit tight under the heat shield. had to bend the shield slightly to prevent any contact. As Ben recommended, no need for the GT straps and bolt straight to the H/E and stock bracket. The flange/inlet pipes were short which made tightening the bolts a bit challenging. According to Ben, this is the result of the the longer design of the 1.8 H/E. Needed a combination of wrenches, sockets, crows foot, etc. I also staggered the direction of the bolts. I suppose can use a shorter bolt but the supplied ones work.
My only issue is the length of the outlet pipe. Was planning to put a stock rear valance (which I do not yet have), but looking at it, I do not think the stock valance cut out will line up/fit with the outlet pipe. Pipe looks too long. I was hoping to get some input from others.
