Do you just use the /4 Djet cable?
I can't see it using the carb trans intermediate pivot linkage, or am I wrong?
Buddy as two 914's that he's building, he needs both a /4 and a /6 box. He mixed up trannys and rebuilt the wrong box for his 3.2 build, the one box from his old Weber carb six engine has a /6 intermediate plate for the linkage. The box he mistakenly built on the /4 core has custom gearing for the 3.2. If it's just a cable linkage on the 3.2 it doesn't matter and l'll just remove the old linkage for his /4 transmission.
If it does matter I'll crack both boxes and swap gears around.
