Hi. My car has aways had a sticky accelerator, which I had attributed to the 90 degree bend in the throttle cable before it enters the engine compartment. PO had done some creative routing, probably when changing over to a carburetor.
Today we pulled the old cable. It was really jammed up and had to cut it at the rear and pull it through from the front. Someone had removed quite a few strands of the cable (more on that coming ...). The white plastic sleeve for the cable is also quite a bit shorter than the replacement part.
When trying to feed in the new cable, it stopped at about 10" into the tunnel. No amount of persuasion would get it past that point. I chucked a coat hanger into my drill and was able to push past the 10" mark, but not without a good deal of binding/friction. And even after that the new cable would not go. The PO probably "thinned" the cable to get it past that point although I am not quite sure how that would be possible.
Here is where I am: There is a dent in the floor pan about 10 forward of the hole for the throttle cable. I can only guess that the tube running in tunnel was kinked or crushed by the dent.
I am thinking I need to cut into the tunnel to get to that point and try to open it up.
So two questions: first - is there another way to run the cable through the tunnel and, second, if I open it up to get at the tube would I be better cutting into the floor pan or the top of the tunnel between the seats.
I appreciate any guidance - Thank you!
