QUOTE(Mark Henry @ Mar 28 2021, 12:22 PM)
I'm assuming you're doing a front cooler set-up with this pump kit?
The pump is likely plugged but you always check, now the oil is coming out of the pump cover, then in to the remote oil filter console mounted to the lower firewall, then out to a Mocal t-stat, then out to your front cooler, return to the t-stat, back out and into the case front top oil galley you tapped.
-I personally would keep the stock cooler and stock T-stat, some mostly racers delete the stock cooler when using the front cooler.
-I'd for sure keep stock cooler if doing only a rear remote cooler.
-Remote coolers I'd use a remote T-stat, the 30mm pumps produces a lot of pressure when cold.
Carbs or EFI you need a wideband O2 meter.
And a good header at least a 1-5/8".
Note always confirm the connections are correct for your gear.
Yes the pump is plugged. Just checked that. Nice shiny brass plug. I do have some concerns about the amount of pressure this produces when cold. I’ll have to be certain to monitor that for sure. What size pump did you use on your motor? And how much pressure does it make?
I will be using a remote cooler / tstat setup with an electric fan mounted under the rear trunk. (914) and keeping the stock cooler as well.
Planning to run dual weber 44idf’s and , you might think I’m crazy but using the same stainless steel exaust/heat exchangers that were on the car. I don’t plan on racing this car. Just an occasional autocross maybe. Since I have put so much time and money into this restoration I will be driving the wheels off of it. Lots of great mountain roads here. And I like to have heat/defrost in the colder months.
The research I come up with indicates the sensor for the wideband is ideally placed 24” downstream of the exhaust which presents a bit of a problem with the heat exchangers.
If you’re familiar with them, there is a short clean run just before bolting onto the muffler. I suppose mounting one there would be better than nothing.
