QUOTE(cary @ Mar 28 2021, 07:53 AM)
Don't know what's proper. But I put it thru the hole in the bar with the provided rubber sleeve.
You don't really want anything hanging down if you can get away with it.
Matt @914Rubber had his right e-brake cable ripped off/out on one of his excursions.
Isn't the hole in the engine bar for the clutch cable? That's the only cable I have with a rubber sleeve in that location. I routed the speedo cable over the top of the bar and zip-tied it to the clutch cable about mid-way between the engine bar and speedometer angle drive to keep it up as high as possible. Don't know what the factory did.
