Hi all, I have done a lot of work trying to narrow down the source of an irritating rattle with my 914. Any insight into what is happening here would be very appreciated!
On very rare occasions this rattle will present itself when the car is in neutral idling (parked - not moving). But always present when the car is moving. It is hard to hear above 20-30mpg, and mostly noticeable when coming to a stop.
It does not matter the position of the clutch, and it is not coming from any of the shift linkage (i can hold tension to the linkage or let it swing loose in neutral and the rattle is still present). The rattle is present in neutral and in all gears EXCEPT for 1st.
1st gear is the only gear where the rattle disappears. if I am coasting to a stop and 1st gear is engaged (with or without the engine running) there is no rattle. If I pop it out of 1st gear the rattle starts immediately.
Also (if relevant), I have never been able to smoothly downshift into 1st gear when the car is moving (I have done it but I have to double clutch/rev match to accomplish it). Could this also be a symptom of this issue or is this normal?
Thanks again!
