QUOTE(DRPHIL914 @ Mar 30 2021, 12:34 PM)
hey you might be able to try a bilge fan from a marine supply store, they could be mounted under there in line, but a good stock one should be fine, my rear aux fan for the heat also went bad and i sourced one from a member hear fairly cheap, like Clay said there are a lot of them out there. good luck!
@DRPHIL914 You're on to my train-of-thought.
Originally, the previous installation had the heater-tube going up and over the engine. To make it look cleaner and supply more air-flow, was thinking to put a blower on each side of the engine, supplying each of the ducts that lead to the cabin, photo below.
I wasn't aware the motor in the photo was a stock 914/4 part, shows how much I know. I'll put up an add in the classified section.
