I had to change out my Front Radiator on my Suby car. In the process of removing the shrouding etc... I had to remove the lower Front trunk latch and the cable attachment. When I re-installed the assembly, I thought I put it in the same spot. I noticed on my test drives and shakedown runs, my hood is popping as if I pulled the cable.
Is there a process to ensure proper security and adjustment?
Is my cable too tight and when the body flexes its pulling?
Move more left, right, up or down??? Yikes??
I am ready to button everything up for good, but need to figure this out.
Thank you all!
Robert
bdstone914
Apr 2 2021, 10:58 PM
Yes it could be too tight. It actually helps to have a small amount of slack in the cabel to open it.
Robarabian
Apr 3 2021, 08:05 AM
Ill try to slacken it up a bit....Thanks for the direction.
QUOTE(bdstone914 @ Apr 2 2021, 09:58 PM)
sixnotfour
Apr 3 2021, 08:32 AM
2 914s 1 boxster (track car) forgot their Hood Pins...a record..covid related Im sure...luckily the factory provides a FailSafe.......Lucky
