Dmidco914
Apr 3 2021, 07:22 AM
Does anyone know who can work on dual empi carbs in Orlando Fl or close by?
rhodyguy
Apr 3 2021, 01:06 PM
Series9 was in Delray. Not sure if Joe is still in biz. IIRC, the Empi knockoffs had some issues. If you are going to run carbs you really should own a copy of CBperformance's Weber manual. You are going to burn thru some C-notes turning your car over to a shop for carb work. What are you using for a fuel pump? That's ? #1. #2 is what are the symptoms?
Al Meredith
Apr 5 2021, 02:53 PM
Try going to "www.redlineweber.com/tech/idf_adjustment_controls.htm" I've found this a good resource . AL
