Building a 2056 with a 9550 cam, Ljet with 912 injectors. Any mods need to be done to the AFM?
ClayPerrine
Apr 4 2021, 07:33 AM
QUOTE(Geezer914 @ Apr 4 2021, 07:11 AM)
No. The extra air flow will displace the door more and that will compensate for the extra displacement.
Clay
Mikey914
Apr 4 2021, 09:18 AM
The 912e runs this setup. The fuel map is set up for a 1.8 on the 914 box, if you have any problems look for a 912e box. There may be a few around as many did go to carbs. They were seen as an upgrade at one time. Funny with the 2.0 L jet configuration the 912e get about 25-30 mpg. One of the reasons most have a lot of miles on them.
timothy_nd28
Apr 4 2021, 11:53 AM
To be absolutely sure, you’ll need to monitor the fuel air mixture in the exhaust.
Bleyseng
Apr 5 2021, 07:21 AM
I would think you should check the air/fuel ratio with a O2setup after getting it running with that cam. On my Westy I had to adjust the afm richer
hcdmueller
Apr 5 2021, 08:30 AM
QUOTE(Bleyseng @ Apr 5 2021, 06:21 AM)
I built a camper special 2.0l for my last bus and definitely needed some adjustments on the AFM.
