Full Version: Vacuum Hose changes
Wew
Hi all,
Have been working on my engine and transmission rebuilds. Almost there.
Question is I had new heads machined and now notice there are no vacuum ports on the heads like my old ones.
I borrowed this schematic from another member and added the thin red line, circle and arrow to the drawing to show what I am talking about.
Do I just remove that piece and plug the hole on the air cleaner?
Do I reroute some lines?
Anyone who has been down this road I appreciate you input.
Thanks,
GaryClick to view attachmentClick to view attachment
rjames
Get rid of the T fitting and route the hose from the air box to the port on the oil filler.
Wew
Awesome...
Thanks Robert!
JamesM
QUOTE(rjames @ Apr 5 2021, 08:25 AM) *
Get rid of the T fitting and route the hose from the air box it to the port on the oil filler.
Also need to replace the PCV on the oil filter with an open port. Ideally you would want to replace the oil filler and air filter housing with the later style ones with a larger port as the single 13mm hose doesent provice adiquate venting without the heads ports.
Wew
Thanks for the input James.
Much appreciated.
914werke
QUOTE(JamesM @ Apr 7 2021, 11:56 PM) *
agree.gif what they said biggrin.gif Only challenge is finding the new hose in that larger 20mm size ... & the late airbox top that accepts it sad.gif
Wew
Looks like I am on the hunt for some more parts.
Thanks for the input.
Gary
Wew
Hi all,
I found both of these on EBay.
Is this what I need?
A 75-76 air filter box and a no pcv just air vent port oil filler housing.
Rich had mentioned a hard to find vacuum hose of 20mm
Can anyone shed additional light on that or share your experiences and resource on solving this?
I plan on keeping the fuel injection on the car, just for clarification.
Thanks,
Gary
Wew
Hi all,
I did my searching and purchase a 75/76 air cleaner housing and oil filler housing with the bigger vacuum opening.
I have some questions about vacuum hose routing.
Per the pic attached and numbered my questions are as follows:
1. Circle #1 Oil filler opening to #2 on air cleaner (large 20mm openings)
a. Please confirm if this is correct.
b. Anyone know of a source to purchase these large diameter vacuum lines?
2, Circle #3 Two vacuum/vapor lines running from the frunk to the engine
compartment.
Question: Two lines and a single port left #4, how should I route these?
As always many thanks to the braintrust on the forum.
Thanks again
JamesM
QUOTE(Wew @ Apr 22 2021, 06:44 AM) *
Hi all,
compartment.
Thanks again
#1 Yes, 20mm oil filter to 20mm air filter. dont know of any source for the original hose, you may need to go aftermarket silicone.
#2 Those are the lines that run to/from your charcoal canister on your gas tank. on the engine bay side one end connects to a port either on your fan housing or engine tin (depending on which fan housing and engine tin you have) and the other side goes to your air filter.
You may need to get a little creative with your house routing as the 75-76 cars had the charcoal canister in the engine bay so #3 in your picture didnt exist and the ports moved around a bit.
Wew
Awesome.
Thank you James!
bbrock
Is the larger hose 20mm ID or OD? Belmetric sells 14x20 braided hose and I thought that's what the larger ports were (vs 12mm ID of the earlier ports). https://www.belmetric.com/braided-metric-hose-oem-c-14_138/
Invision Power Board © 2001-2024 Invision Power Services, Inc.
