So I went and purchased one of the Type 4 CNC oil pumps off the Samba. I've been looking for a good used Type 4 pump with limited sucess. I did start a thread long ago looking into what it was going to take me to rebuild a pump by mixing and matching parts and/or by remachining some housings to make serviceable parts. This is another case were procrastination may have paid off.
Here's the old thread:
http://www.914world.com/bbs2/index.php?showtopic=338311
New CNC Pump Overview:
30mm gears vs OEM 24mm (not thrilled with 30mm gears for a stock rebuild but will have a use for this in the future).
Idler shaft is supported in double shear just like OEM
Fit and finish of parts appears to be good visually
Idler gear shaft is not pinned to the housing - same as OEM but I view this as needing to be fixed
I still need to sit down and do some real inspection measurement of flatness, gear clearances, etc. Looks to be a very viable direct replacment for NLA Type 4 pump.
I will modify the idler shaft by pinning it to the housing to prevent migration that plagues overheated OEM pumps that are in circulation.
Here's the pictures of it:
Front
Back
Disassembled
Idler shaft as received - not yet pinned
