QUOTE(johnhora @ Apr 8 2021, 11:58 AM)
Nothing wrong with that one...they all look like that on the bottom side after years of use. That's a good one from Bosch with Germany mfg
try it out and see if you're getting approximately 14v at about 1k rpm
you can take the tape (usually yellow) off and open it up and check the inside if you want.
What I have found testing them is that some get hotter than others...don't touch that rusty part after it is running if will flat burn you...
I think this is why so many of the relay boards are cracked in this are on the bottom and why there is a slot below the regulator to help cool the area.
I found the new Bosch solid state ones to run cooler.
I have a couple used Bosch ones listed if you need an extra one.
Thank you, I’ll test this one out like you said.
I found this one on line but the #s are not quite the same. It says it will work on a 914... it says NOS
Cheers,
John
