I will be pulling my transmission this weekend to replace the throw out bearing and also to open up and put back the stock 4&5 gears. Right now i have the bolts that are drilled out for being safety wired, and i was planning on ordering the new washers and wire, but reusing the bolts. from what i have read this seems to be ok acceptable practice.
- gaskets, grease, cone screws, wire , washers , throw out bearing, cup retainer and guide--- clutch disc has about 7500 miles on it and i feels just fine so unless i get in there and find issues i will probably not change it out. Flywheel pressure plate and disc were done at the same time -that was 9 years ago when i rebuilt the transmission at the Dr. Evil clinic- i am currently leak free,
anything else supply wise i need?
Phil
