Hi all-
The car is 1973 and had a "caged" momo accordian boot- style adapter attached to the component pictured below (yellow circle) which I have removed.
I cannot figure out how to remove the hub/spacer circled below. Subsequently, I cannot address wiper and turn signal switches, let alone put stock steering wheel on.
I suspect it is attached to the circlip on the steering shaft, but cannot access it currently.
I do not see it listed in the exploded diagrams. And I know there is differnce between late and early steering columns.
1- is this a 'stock' component or have you seen this part before
2- if so, how do I remove?
3- what am I missing?
Thanks
Greg
