QUOTE(Ansbacher @ Apr 12 2021, 03:43 PM)
So the answer is.....yes??....(a bit too technical for me). The reason I asked this question originally is to cover the following situation:
Let's say I know my car is set at 29 degrees at 3500 RPM and I want to bump it up to 30 degrees. It is an early Sunday morning and I don't want to bother the neighbors by revving the engine to 3500 RPM to make the adjustment. Therefore, can I just bump up the timing at idle by one degree to achieve 30 degrees at full throttle?
Ansbacher
Sorry...simply yes. However like Brant says...make sure you disconnect the vacuum advance or retard side and plug the TB side if a stock dizzy.
This won't account for dynamics when the engine is on however....which was what thought you also wanted to know.
Personally I'd not worry about what the neighbors think in that I'd want to know what the engine is doing throughout the rpm range with everything running and working.
