burlybryan
Apr 13 2021, 07:53 AM
Does it need to be energized to test vacuum or can I just bench test it with vac hose (properly clamped) and a mityvac? I have a few on hand and while all test correctly for resistance on the appropriate pins, I'm not able to get any vac with my mityvac. Am I missing something or are the diaphragms all toast?
914werke
Apr 13 2021, 07:57 AM
if you can apply say 5 or so #'s of vacuum on the port & it doesnt hold (at all or drops to 0 in a period of time) its toast.
brant
Apr 13 2021, 08:05 AM
its that simple... if your mighty vac is working correctly... they must be all toast
I believe Paul Anders said 15Hg of vacuum?
but would have to go check to be sure
brant
BeatNavy
Apr 13 2021, 08:22 AM
QUOTE(brant @ Apr 13 2021, 09:05 AM)
brant
Yes, 15 in Hg is the standard test, simulating idle vacuum on a stock engine. I've read a couple of specs about how much it can leak (e.g., < 5 in Hg in a minute, or < 5 in in FIVE minutes), but if it won't hold any vacuum it's done.
http://www.tangerineracing.com/mpsdiaphragm.htmHere's Brad's page:
https://members.rennlist.com/pbanders/manif...S%20Diagnostics
bob164
Apr 13 2021, 08:43 AM
Double check you gauge and connections to make sure these are valid readings. Pull a vacuum on a vacuum cap first then work up from there.
914werke
Apr 13 2021, 08:50 AM
15Hg=7psi approx
burlybryan
Apr 13 2021, 09:14 AM
Got it. That's what I thought. I can pull vac with the mityvac on my skin, so I think it's fine.
Thanks.
