QUOTE(9ONE4_JIM @ Apr 14 2021, 04:58 PM)
what problems are you having that makes you think it's bad
I have used ones if needed...
I just acquired this car and am in the process of "Dialing-It-In." During a 40 mile trip back home from my mechanic (my first night drive in this car) I noticed that the dash lights were modulating from dim to brighter about halfway into the trip. I then noticed that my headlight were doing the same thing.
During a call to the mechanic the next day he stated that the culprit is the voltage regulator. In that he has been working on these cars since 1974 I took his assessment seriously. Your thoughts...
Sounds more like a light switch problem. Check the voltage across the battery terminals with the engine running and not running. It should be higher when running.
You might need a new mechanic too.
