Hi guys,
1974 2.0 FI.
When turning left all of a sudden the turn signal relay starting buzzing and the left/right arrows started blinking . Wiggled the stalked a bit and it stopped but it happened again short after. I have the hella relay with a buzzer which I normally only hear on start-up with the ebrake on. Turnsignals, hazards etc are working and the big red one only comes on when the ebrake is on so I don't think it is brake/master cylinder related.
Assumed it was a faulty turn signal relay so I changed it with a Uro one I had lying around. The car is driveable (no buzzing cause the URO one has no buzzer
) but the relay keeps clicking and the arrows keep flashing.
Where shall I start ? The stalk (is a rather new one) ? The relay itself ? someone of FB suggested that the connectors below the steering column are not well connected (still need to check). Ground issue ? but I cleaned them all (I guess ALL) a couple of months ago.
thks yr support
krgds
Dax
