TimT
Jul 20 2005, 07:47 PM
Sometimes I just get a good laugh out of these
Look here
Flat VW
Jul 20 2005, 07:51 PM
QUOTE (TimT @ Jul 20 2005, 05:47 PM) |
Look here
Why not just use lockwashers, do they make "cupped" lockwashers?
J
ejm
Jul 20 2005, 08:02 PM
just don't get those guys started on car wax
lapuwali
Jul 20 2005, 08:15 PM
Gee, I wonder if 914 lug nuts regularly see 1600-1800dF temperatures. Maybe it's only those high-power 911s...
Car wax is very important for aerodynamics...
redshift
Jul 20 2005, 08:22 PM
I look at Jack Olsen's car, and I drool... and then I remember...
'he's one of them'...
M
Brando
Jul 21 2005, 10:29 AM
I just had to shit in their campfire.
Is it just me, or do some 911 owners like to blab alot? I have never seen such long threads about car wax, the right lug nuts to use, large discussions on wiper blades... etc.
URY914
Jul 21 2005, 10:59 AM
"I got WD40 on my lug nuts, OMG what do I do!!??!!??"
Paul
anthony
Jul 21 2005, 11:07 AM
QUOTE (Brando @ Jul 21 2005, 09:29 AM) |
Is it just me, or do some 911 owners like to blab alot? I have never seen such long threads about car wax, the right lug nuts to use, large discussions on wiper blades... etc. |
LOL, Blab? I thought this board was OT blab central?
The Pelican 911 board is IMO one of the best Porsche discussion boards out there. Sure a few owners are into bling but there are also many more highly technical discussions.
Aaron Cox
Jul 21 2005, 04:40 PM
QUOTE (URY914 @ Jul 21 2005, 09:59 AM) |
Paul |
hahahha.....
its totalled......
redshift
Jul 21 2005, 04:43 PM
I knew a guy who used Johnson's Baby Shampoo to remove WD-40 from some aluminum trim, I don't know if it's safe to use on lugs though.
M
Jul 21 2005, 04:44 PM
QUOTE (TimT @ Jul 20 2005, 06:47 PM) |
Sometimes I just get a good laugh out of these |
ok, then answer me this:
why would/should i put anti seize on my lug nuts?
what's the reasoning behind that?
Andy
redshift
Jul 21 2005, 04:49 PM
So you can torque them to spec, and remove them when you need to, in 6 months, instead of risking the thingy snappin' off.
DamN! These cars came from Germany! You are supposed to have all the answers!
M
Jul 21 2005, 04:53 PM
QUOTE (redshift @ Jul 21 2005, 03:49 PM) |
So you can torque them to spec, and remove them when you need to, in 6 months, instead of risking the thingy snappin' off. |
huh? i *never* had a lugnut seize on me ...
Andy
TimT
Jul 21 2005, 05:21 PM
QUOTE |
ok, then answer me this: |
first off you wouldnt put the anti sieze on the lug nut..
you might apply a small boogers worth to the stud in the area where the lug nut grips.
The anti sieeze helps those people who only remove the wheel when they have to, ie every two or three years for brake pad replacement, or the occasional flat.
We who swap wheels with some sort of frequency dont need anti sieze.
What cracks me up is the Nth degree which something quite simple is analyzed..
Bolted connections, Welding, Structural analysis are my lively hood. If you reduce the friction between elements of a fastener the torque applied will be less than a dry set of fasteners
brant
Paul |
Paul, what the heck were you thinking?
wd-40 is heavy stuff man....
get it off of there
lol
brant
Andyrew
Jul 21 2005, 05:54 PM
I have had a lug nut seize on me...
But that was at pick and pull... On a camero that was sitting there for 2 years, and I was getting the wheels for a friends camero.
good times...
not.
Dont use the stuff btw....
Joe Bob
Jul 21 2005, 09:31 PM
I've seen more than a few alloy nuts leave the bottom end of the face on the wheel and it's a BITCH to get the curved part off.....doesn't happen if the nuts come off and on on a regular basis....or if you use anti-seize.....
Two of the cars I have use steel open head nuts....thinking of doing it with the 911 as well. Easy way to chinger up a nice Fuch having to chisel off half an alloy nut that came apart.
redshift
Jul 21 2005, 10:03 PM
QUOTE (brant @ Jul 21 2005, 07:21 PM) |
wd-40 is heavy stuff man.... get it off of there
lol brant |
And it floats on water!!
WATER MUST BE VERY HEAVY!
Brando
Jul 21 2005, 10:32 PM
Unlike some of you with 911 or real 914-6 5-lug setups, us 4-lug bolt guys do have serious siezing issues with our lug bolts. Ever have a circa 1970s car with lug bolts that won't undo? It's not like we get aluminum Lug-bolts that don't oxidize. Steel rusts together. That is the point of anti-sieze compound on steel-to-steel surfaces under load.
brant
Jul 21 2005, 10:34 PM
QUOTE (redshift @ Jul 21 2005, 09:03 PM) |
QUOTE (brant @ Jul 21 2005, 07:21 PM) | Paul, what the heck were you thinking?
lol brant |
WATER MUST BE VERY HEAVY! |
Y E A H... (duh)
why do you think his car is water cooled!
brant
