QUOTE(Nacho @ Apr 24 2021, 07:04 PM)
QUOTE(pilothyer @ Apr 23 2021, 11:51 PM)
PET Shows that the 914-4 and 914-6 shares the same number for that part. Auxiliary Support 90134101303 Even the early 911 except for the end number 901341013(02) which was because it was aluminum. Can you see any difference between the two you have.................just curious I guess
I remember when the "hot set-up" was to get the same part 90134101302 off of the early 911 and since it was aluminum you could shave a few pounds of weight. It bolted right in but there were no holes to bolt on the protective cover plate at the front.
http://www.914world.com/bbs2/index.php?sho...y++support++911You will also need to change the lower ball joint if your car is a 74 and the 911 Boge struts are 72. Your current ball joints should be wedge bolt and the 911 struts pinch bolt.
Nacho
I would have the struts converted to use the wedge type ball joint. Porsche changed the design because they had issues with the early pinch type ball joints coming loose. A lot of the early ball joint struts are wallowed out at the bottom because of this issue.
Zims (allzim.com) does the conversions. Contact
@partsguy22 for more info.
BTW.. The 914-6 we have was the first ones they did. The only way to tell is to look at the bottom of the strut. The rest looks just like it came from the factory.
