Hardware needs:
1. Rain tray screws, Qty: 2, P/N: N 014 142 3
2. Fan to hub ‘Spacer’, Qty: 1, P/N: 021 119 121
Fan Spacer
3. Would someone also be able to confirm the type of bolts for impeller fan to hub connection?
I find the PET hard to interpret in some instances.
Item 6 in the diagram shows - N 010 246 4, M8 x 45 hex-head bolt. Is this it?
If so, then will need items 6, 7, and 8 (bolt, spring washer, washer).
Probably easy to get at a hardware store but checking here first.
Thank you,
Sean
