Cal
Apr 25 2021, 05:10 PM
I need help wiring up my rear fog light. I finally have the correct 2-way fog light switch, the correct wiring harness and the rear fog light with brackets. I’m not sure which wires attach to which terminals on the 2-way switch. Also, the brown ground wire on the harness is much shorter in length....where does it attach, in the engine compartment?
Jett
Apr 26 2021, 09:34 AM
From our mechanic...
As I recall, and it’s been a while.
N is fog
NR is rear fog
48 is from headlight switch
- is to ground, I believe I made a short ground lead.
That’s how I remember it. Use a meter to confirm.
Ground on harness goes to frame rail ground, drivers side in engine compartment. But it could have been in the trunk. It was obvious when the harness was laid out in the car.
