QUOTE(hex123 @ Apr 27 2021, 01:50 PM)
The whole engine doesn't need to be rebuilt, it can easily go 150-200K, just the heads need to be touched up. 5K miles a year will give you 12 years before you should need to do this. The heads don't just drop seats, most cases it's overheating due to grease caked dirt clogging the fins...or a rag in the fan, mouse nests, etc. So the head mantainance is a good excuse to check and clean the cooling system.
I don't see how an ECU, bearings, rods, etc. would increase longevity, just like quality heads won't replace good mantainance habits.
What is unrealistic is expecting a 50 year old car with an 90 year old engine design to perform like a modern car. Really if that's what you want then respectively maybe you would be better off with a modern car.
With a modern ECU you have more supervision as to what is happening with the motor and can program fail safes like detune accordingly to prevent damage due to overheat or even power down the engine if you suddenly lose oil pressure. The more precise fuel metering helps lower oil dilution due to over rich settings. I've hear that chevy bearings are superior in material quality to the VW offerings, stronger and lighter rods and pistons to limit stress exerted on the cranks. I think all of these have some merit in improving long term engine life.
I don't mind normal maintenance but when the maintenance requires dropping the engine and you don't have a garage and a lift to work on, you have a strong desire to make improvements where possible to limit the Maintenance events that requires engine removal.
-Chevy bearings or rods won't fit a 2.0 crank, you would have to weld the crank journals and re-machine to use them. For stroker cranks I prefer to use the 78mm size because you can use the larger VW type one rod journal. 80mm Chevy journal (actually a Buick journal not chevy) stoker cranks will have a shorter TBO than engines with the T1 rod cranks.
-Aircooled engines need a ballpark 12.7:1 AFR under load as the fuel charge actually provides some cooling, no way around this. Overheating head and oil temps plus pressure can easily be monitored with gauges and/idiot lights.
I'm not tying to steer you away from an aftermarket ECU, I have an aftermarket ECU on my 2600cc T4 and I'm gathering the gear to do my 3.0/6, I'm just trying to help you have realistic expectations of what a aftermarket ECU can and can't do.
BTW I have hundreds of stock and performance T1 and T4 builds, plus a bunch 911, 996, and 997 builds under my belt.
