freezing14
Jul 21 2005, 07:58 AM
Got the traling arm off and i am changing the bushing,, the old one were hard to convice out , but the new one doe not want to cooperate, it goes ok on the one side until it hits the second side and then the other one always pops out,,, so what is the best way to put those back in
URY914
Jul 21 2005, 08:11 AM
One of the WORST jobs on a 914.
freezing14
Jul 21 2005, 08:26 AM
i know , i have tried the hammer , but is there a trick or should i consider getting a press ( i got a line on a 12 tons)
URY914
Jul 21 2005, 08:53 AM
Are you instaling new stock rubber ones or plastic?
Joe Ricard
Jul 21 2005, 09:23 AM
New stock Rubber one's ???????
Well my question is did you match fit the Plastic bushing to the shaft and housing?
10lb of bushing won't fit in a 5 lb housing.
freezing14
Jul 21 2005, 09:45 AM
I am using both stock rubber bushing and bolt
Jeffs9146
Jul 21 2005, 10:06 AM
QUOTE |
I used a press and a bunch of grease! It went together as smooth as snot!
Jeff
URY914
Jul 21 2005, 11:01 AM
Yes, the rubber one are better to press in. Nice and slow and smooth.
