Mikey914
Apr 27 2021, 04:18 PM
Yes had the opportunity to make these ad very cost effectively. We are offering both the early and late front trunk springs finished in enamel just like factory (well kind of like factory).
What I mean by this is factory had them dipped and if you look closely there was a lot of excess paint. I think we did a better job. You be the judge.
We made the early at a 7.5" coil and the late at 8.375"
No that the factory only used one part number as they superseded them with the longer springs. From a manufacturing these I can tell you that the early has a higher tension load. This is probably why the late superseded it.
Will have these ready to ship in less than 2weeks (being finished now) , so who's in?
dlee6204
Apr 27 2021, 04:47 PM
Im in for a set
rfinegan
Apr 27 2021, 05:37 PM
Yep I'm in for a set. 75 late
PanelBilly
Apr 27 2021, 06:12 PM
What years are early and late?
56kabrio
Apr 27 2021, 06:23 PM
I’m in for a set as well, but also don’t know when the early / late change occurred.
Thanks
Mack
Mikey914
Apr 27 2021, 09:41 PM
Its my understanding that somewhere in 73 (I was thinking early 73) since they were superceded both will work.
bob164
Apr 28 2021, 12:08 AM
I'm in for a set of late ones.
Dobbsy
Apr 28 2021, 12:24 AM
Early set for me please.
Mikey914
Apr 28 2021, 12:45 PM
Getting a set out to Doug today.
Let us know what you think.
-Mark
Luke M
Apr 29 2021, 07:06 AM
1 set of early and 1 set of late please.
914sgofast2
Apr 29 2021, 11:08 AM
I will take a set!
Mike D.
maf914
Apr 30 2021, 04:25 PM
One set of model late model springs, please. Thanks, Mark.
Mikey914
May 1 2021, 11:59 AM
These are the hinge bolts at $3 when you buy the springs. Thought I would add them in as you already have the spring off.
Biggles
May 1 2021, 01:06 PM
I'm in for one early set
orthobiz
May 2 2021, 07:35 AM
Most of my cars have had the springs reset at the third (farthest) slot to cure a sagging front hood.
So, will the new late springs allow placing the spring closer to the pivot?
Or would the new short springs work better to eliminate sag.
Paul
jim_hoyland
May 2 2021, 07:57 AM
QUOTE(orthobiz @ May 2 2021, 06:35 AM)
Paul
I was wondering the same thought. If someone has done this, tell us the outcome
And Thanks 914Rubber for another needed part !
Mikey914
May 2 2021, 09:50 AM
The "early' shorter springs would jive you the additional tension you are looking for. They will have a higher preload.
Mikey914
May 3 2021, 10:22 AM
These will be done from finishing this Friday!
Can-Am
May 3 2021, 01:04 PM
I'd like 2 sets please, one early and one late.
Mikey914
May 10 2021, 01:54 PM
PMs going out tonight this will close the 20th.
Gearup
May 10 2021, 03:05 PM
Set for a 1970 and the bolts please.
Mikey914
May 10 2021, 11:02 PM
PM sent to all so far !
Will close this out the 20th
914e
May 10 2021, 11:28 PM
I will take a set for a 76 with bolts.
Dredwin
May 11 2021, 12:47 AM
I’ll take 2 sets of early with bolts
pvollma
May 12 2021, 01:55 PM
I'll take a set for a 76, plus a set of the hinge bolts, please.
dlee6204
May 12 2021, 03:25 PM
I received one of the first sets from this GB and was able to get a set installed on a '75. Overall the final finish is better than original IMO. Tension was where it needed be and lifts the hood just fine. It's another nice reproduction from 914Rubber!
Click to view attachment Old vs New
Click to view attachmentClick to view attachmentNew
Click to view attachmentOld
frostyf
May 13 2021, 10:37 AM
Mark, can you put me down for 1 early set please with bolts.
Thank you,
Nick
jim_hoyland
May 14 2021, 05:53 PM
Order submitted with 2 bolts.....
jims914
May 14 2021, 07:23 PM
QUOTE(Mikey914 @ May 10 2021, 12:54 PM)
I am in for a early set.
Mike D.
May 14 2021, 10:24 PM
I'll have a set with bolts! - for a 74
914_7T3
May 15 2021, 11:14 PM
@mikey914 I'm in for a late set of springs. PM or email me a PayPal Invoice.
Thanks.
913B
May 15 2021, 11:23 PM
I would like 1 set of the early ones.
Thanks
Jett
May 16 2021, 08:05 AM
I’ll take a set for our 73, thanks Mark
Rob914
May 18 2021, 10:22 PM
One early set with bolts please.
VoPo914
May 19 2021, 09:24 AM
Im in for a Late set with bolts.Thanks Mark!
Rods914
May 19 2021, 05:16 PM
I will take a set with bolts for a 73 Thanks Rods914
Mikey914
May 20 2021, 01:04 AM
PM's sent to all so far. This GB closes in less than 24hrs.
mlmgm
May 20 2021, 10:14 AM
pvollma
May 20 2021, 07:39 PM
QUOTE(Mikey914 @ May 20 2021, 03:04 AM)
I requested a set for a 76 plus the hinge bolts back on 5/12, but have not received a PM:
My post
Mikey914
May 20 2021, 08:25 PM
Sorry I missed you. You got one now.
-Mark
ibmiked
May 21 2021, 03:31 PM
QUOTE(Mikey914 @ May 20 2021, 10:25 PM)
-Mark
I’d like an early set but also need a bunch of other stuff from you guys. What’s the best way to make that happen?
