So have been troubleshooting my warmed-up engine cutting out while slowing from 30+mph to a stop. The engine has been newly refurbished (rings, honed cylinders, everything cleaned/checked, new hoses, injectors rebuilt, relay board rebuilt, etc.) I assume it may be related to vacuum lines and have clamped all of the ends to ensure no leaks. AAR is working.
I am down to thinking it is the MPS. The car was inoperable for 10+ years prior to purchase and has a used spare. Correct MPS part number is showing #0280100049 for the car but MPS connected to engine is Bosch #0280100019 and holds 15in HG without leak down.
Spare is #0280100001 (which in doing some research appears to be for a VW Type 3 and has had epoxy removed and leaks (will hold vacuum if I cover the adjustment screw end so just needs epoxy to seal.
Engine runs well otherwise - at least until I can get it on the road for some longer higher speed runs - not willing to venture to far out until I get this solved first.
Before I try to find a used MPS with correct number, any ideas from the board?
