RestoReese
Apr 28 2021, 01:10 AM
Looking for a functional Manifold Pressure Sensor (MPS) Bosch Part #0280100049. No leaks and good Ohm readings necessary.
Or if you have a core you want to donate, will gladly will pay shipping. My cores aren't correct part number so can't even get refurbished.
bdstone914
Apr 28 2021, 05:08 PM
QUOTE(RestoReese @ Apr 28 2021, 12:10 AM)
@RestoReese I have two with that part number. Will need to test them.
RestoReese
Apr 30 2021, 11:07 AM
I am interested. I pulled the testing procedure below from rennlist:
Using a hand vacuum pump with a gauge (e.g., Actron model from Checker, about $30), pull a vacuum of 10 in. Hg on the sensing port of the MPS. If a vacuum cannot be pulled or it leaks down (< 5 in. Hg in one minute), then the sensor is leaky and must be repaired. The usual causes of vacuum leaks are a cracked diaphragm, a leaky body flange seal (either an o-ring and/or a flange seal), or a leaky part-load stop seal (paper seal, unobtainable - gasket sealant may work). Some people have reported luck with repairing the diaphragm using solder or epoxy, or a sandwich of aluminum foil and RTV (!), but such a repair is not recommended. The diaphragm is fully flexed each time the engine is under full load (open throttle) and it is highly likely that any repair will only hold for a short while. The usual way of getting a repair is to do a rebuild exchange with either Performance/Automotion or Automobile Atlanta.
If the vacuum test is passed, check the coil resistances. The primary coil is measured between terminals 7 and 15 and should measure about 90 ohms. The secondary coil is measured between terminals 8 and 10 and should measure about 350 ohms. Also check the coil isolation - there should be no continuity between either of the coils and the case.
gvlb914
Sep 22 2021, 07:58 PM
QUOTE(bdstone914 @ Apr 28 2021, 05:08 PM)
Hello bdstone914
If you still have one of these sensors available 0 280 100 049, I'd be
interested for my '72 1.7.
Thanks
gvlb914
carl k
Sep 23 2021, 10:14 AM
@gvlb914 I have a 049 MPS core (does not hold vacuum).
Click to view attachmentregards,
Carl
white1975
Sep 23 2021, 06:29 PM
i have a 022906051a have not tested yet
