Hi everyone, at the moment I'm rebuilding my engine. It was a 1800 and it will become a 1911cc one. I will try to get the FI working and if not change to carbs. Right now I'm working on deck height and all looks oke.
Also I bought new heads because the original ones suffered a dropped valve. I believe these are AMC heads but I'm not so sure about quality. I'm building a normal 914 without power increase or so... I will increase the CR a bit to approx. 8.1. I disassembled the heads and saw that the valves were not lapped in, so I did it myself.
I also cleaned up the ports (done that before on cars...) and they now look acceptable. I polished the cambers and tried to minimize the pitting, for me acceptable.
My biggest concern are the valve seats in the heads, they seem pressed in and then they pressed at some point around the seat (indentations visible). Is this oke? Will this last during normal road use? Any ideas are welcome...
Setup for deck height measurement
Cilinder head (the valves you see are old ones ground down, used to protect the seats during polishing)
Seat with indentations around the seat
New valve before lapping
New valve after lapping
