QUOTE(930cabman @ Apr 30 2021, 04:29 PM)
I am trying to be a cheapskate with this part of the build, I would entertain a used system. $800.00 or more is not in the budget.
Pm if something useable is available.
Are the heat exchangers different from 1.8 and 2.0 motors? 1974 to 1975 model year?
truthfully I have no idea and not sure how to identify what I have
try living in australia. any of the options come out at well over 1K aud landed!
carefully examining a standard muffler for the late VW kombi sold here (type 4 engine), revealed it was almost exactly the same as one for the 914. i say almost.
the difference is in the inlet pipes mounting flanges. they are upside down (the other way around on a kombi). the kombi tail pipes exit rh side of car (passenger side in USA).
and the strange dents in the muffler accomodate the fit to the u/s of the fan housing etc.
i had a ss kombi muffler, very well made and probably about 25/30 years old. we cut the mounting flanges off and re-welded them on the other way around. cost me a lot less than 1K. its one option for a 1.7/1.8 up to 74. you can still pick up standard kombi mufflers in the USA for affordable prices. if you are any good with a welder you can do the mod yourself.
it is in fact all dansk are doing too (as per originals in 70s), they also remake the muffler for kombis and type 4s. its the same muffler. during manufacture they weld the tapered inlet pipe flanges on the other way around. check what a dansk kombi muffler is sold for on some vw sites. prices can be lower i have noticed. makes you wonder?
one thing to note. the tone of the ss kombi muffler is not as good as the original straight steel mufflers. its kind of higher pitched sound. as per ss heat exchangers.
if i lived in the usa i'd be seriously considering the beautiful mufflers made by a member here and mentioned above. they look the goods.
back in the day, there were mufflers and there were mufflers, even from the factory.
they looked the same on the outside but had different internals with different levels of restriction (and noise). i think the 914s often ran what is called a sport muffler, often as a replacement to improve the sound by owners. these mufflers were available from the factory dealers. the external appearance was the same.
