QUOTE(JeffBowlsby @ May 3 2021, 03:38 PM)
Not only does the Djet CSV have full time power to it, it also has full time pressurized fuel to it.
It can cause a rich mixture just by leaking which they are know to do. You cans send the valve out for cleaning and pressure testing to verify or just completely remove it from the engine fuel and FI harness.
Wait, I thought we just established that it is only supposed to get power when cranking?Good call out about it possibly leaking. I didn't even consider that. I am fairly certain that it's firing all the time when plugged in because even when the engine is warm unplugging it alters the way the engine runs (runs more lean when disconnected).
Since I don't need it, maybe I'll try
removing the injector and plugging the hole on the plenum somehow blocking the fuel line that goes to the injector. Trying not to get too excited yet, but maybe this is the source the car's intermittent issues. If it's leaking, it's likely that it could be doing so inconsistently which would certainly explain the erratic lean/rich behavior.
