QUOTE(mobymutt @ May 6 2021, 09:31 AM)
...it seems you are indicating that JB weld is not a solid long term fix, and I should really put an NPT plug in there.
No, that wasn't a commentary on the efficacy of JBW, as I never did that.
Both times on mine - one on each side - I "field-fixed" it at the track by slightly swaging the inserted end with an appropriate-sized socket, slagged it with silicon, and tapped it in with a small hammer. It seemed to "permanently" fix it for the time being.
There was actually a third time I had a similar problem, with Chris Foley's Fprod engine, where the hose - tightly worm-clamped - slid off the tube (this one was on the aluminum valve cover.) That was "field-fixed" by drilling a hole across the worm clamp, hose, and tube and inserting a cotter pin, along with a lot of silicon. It still exists on Chris' engine to this day...
All three times, the side that popped off was on the outside of the corner. Not only did that make a friiiiggin mess on the track, it also implied to me that that side of the valve cover was likely getting filled with oil and the increased fluid pressure led to the failures. Just a WAG, but it seems to follow.
After all this, and after reading Hoffman's opinions, when I rebuilt the engines (street and track) I removed the vent tubes and and drilled-tapped for NPT plugs.
Greg
Edit,..I still chuckle at this...
