Turn lever is operating all electric functions correctly, except after turning the wheel the lever is not returning to the off position when wheel has returned to zero degrees.
The car came with a replacement Steering Column Group installed, no idea how long it has been in there, and it also came with a one out of the car that I assume is the original. No idea how to tell what normal is, since most likely it was have issues and needed to be replaced.
Steering wheel is original to car, and the turn cancel ring appears to be in perfect condition. The ring is installed to the right side, opposite the lever which is on the left (1971 only has one lever).
Any ideas what could be the issue and how to resolve? Or should I just leave it and either manually return
