devious rhesus
May 7 2021, 07:43 AM
Hello! Looking to make a hot motor for my 914, and want to base it off of the early sand cast 6 cylinder cases. I believe they swapped to magnesium in 1969, so anything prior to that please.
The more complete the better, but also interested in just the case. Please PM me if you have one about! Only caveat being that it should retain the stock bore. Want to make a 2.0!
Thanks much!
brant
May 7 2021, 09:31 AM
they go for a lot.
I have one I could sell
but they are not cheap...
15K with 67S heads,
turns over, needs rebuild.
complete short block
brant
devious rhesus
May 7 2021, 09:51 AM
QUOTE(brant @ May 7 2021, 10:31 AM)
they go for a lot.
15K with 67S heads,
brant
That IS a lot! I will send you a PM.
johnhora
May 7 2021, 01:37 PM
Jett
May 7 2021, 01:56 PM
I was lucky enough to find one and then was shocked by the rebuild cost…
That said, the motor will work well in a six conversion.
sixnotfour
May 7 2021, 04:04 PM
I have several..bare or complete ..PM me your desire..69 S heads nos..$$$$$ 1968 engine 100% complete..runner..
roblav1
May 7 2021, 07:34 PM
Early 1968 engines were aluminum and changed to mag midyear, about the same time they changed the rear decklid. A 930/02 engine would be better and probably overall cheaper.
brant
May 8 2021, 06:10 AM
QUOTE(roblav1 @ May 7 2021, 07:34 PM)
Hard to build a 2.0 engine on a 3.0 block
roblav1
May 8 2021, 03:42 PM
I meant to say to build a thereabouts 3.0.
devious rhesus
May 9 2021, 11:03 AM
QUOTE(roblav1 @ May 8 2021, 04:42 PM)
I am trying to build a motor for vintage racing, so unfortunately I am limited to a 2.0! I think the 3.0 might be TOO noticeable of an advantage
flyer86d
May 9 2021, 03:03 PM
I understand your desire for an early aluminum crankcase for your build. At the cost of one of those crankcases today, why not consider a late 2.4 crankcase which is lighter, has squiters, and have been built into higher HP engines that your 2 liter will ever make. Just saying.
Charlie
gereed75
May 9 2021, 07:33 PM
Before you go to all of that expense, check with the vintage race groups you intend to run with. In my area, northeast states, nobody really cares. Pretty much run what you brung.
There are some organizations who uphold class racing specs, but even those will probably let you run, albeit in some higher class
If you are going to Europe, probably a different story. Good luck.
May 9 2021, 10:02 PM
QUOTE(flyer86d @ May 9 2021, 04:03 PM)
Charlie
2 liter aluminum race engines push 250-280.
