QUOTE(Tom_T @ May 8 2021, 11:53 AM)
Brent -
You can wire the audio/radio unit to bypass the ignition switch - directly into the dash wiring harness.
However, you'll have to turn it on & off at the radio switch, & not forget to turn it off whenever leaving the 914 for more than a few minutes.
I can speak to the dead battery problem if you forget!
That was how mine was set-up by the P-dealer & when I bought my `73 2L from the OO back in 1975.
Most old pre-1980s cars were set up that way from the early days before the ignition switches with an accessory position was common.
Tom
Thanks Tom, Yeah, I know I could rewire the radio but don't like to do that. Prefer to have all power switched off with the key.
@Steve I did not know the sixes have an accessory position on the switch. I knew I'd learn something from my stupid question.
I have the latest Pertronix which is supposed to be immune to burning out when the key is left on too long, but it still makes me paranoid. I've been disconnecting the positive wire from the coil when I leave the key on for long periods without the engine running just to be safe.
