Solved: ignition switch was cracked but working. ignition wire was shorted in the engine tunnel where previous owner did repair work and had cut the wire leaving it exposed it grounded to the floor pan.
Pretty sure I need a new ignition switch although it bothers me that it went out "suddenly"
I have no voltage at the yellow wire on the starter when I turn the key.
I have no voltage at the large yellow wires on the seatbelt interlock relay with the key in the on position or when I turn the key to start. I disconnected them and plugged them together to bypass the SB interlock relay thing which I thought would eliminate this as a source of any problem. The black wires seem to be tied together but disconnected are those supposed to be grounded? My SB interlock relay is loose and not bolted down. The Black wires have 3.5 volts. Some other wires show negative volts in tiny amounts. Only one wire , a brown wire has 11.5 volts and it is loose, is not connected to anything.
The green and red lights are on the dash and stay on when I turn the key but nothing happens, although all the four relays by the fuse box "click"
The fuel pump fires for a couple seconds when I turn the ignition as well. Most of the lights and signals work on the car.
I suspect the ignition switch is there any way to test it without disassembly?
Any other possible source of this not cranking?
